Why is everyone wrapping their tires with plastic wrap? Does this actually provide a benefit or is it just a fad? You see everyone wrapping their tires when storing them in trailer as well as when they are on the car so was just curious on the reasoning.
Plastic Wrap?
Any dirt on the tire will draw oils out. If you treat them, it will also keep the chemicals from evaporating as quickly, lolOriginally posted by kingmod5 View PostWhy is everyone wrapping their tires with plastic wrap? Does this actually provide a benefit or is it just a fad? You see everyone wrapping their tires when storing them in trailer as well as when they are on the car so was just curious on the reasoning.Modern Day Spec Wedge Racing
Also keeps them out of the sun light and UV rays and etc. Just because you see a tire wrapped don't mean it's treated with dope. Most serious teams wrap their tires after cleaning and they dry just to keep them clean and protected and allows you to move the car around if needed without getting dirty. We usually leave ours on until we race, meaning we leave it on when we push or drive the car thru tech just to keep them clean.
Yep....I watched Josh Richards team member cut off the plastic right before he rolled onto the track for qualifying.Originally posted by billetbirdcage View PostAlso keeps them out of the sun light and UV rays and etc. Just because you see a tire wrapped don't mean it's treated with dope. Most serious teams wrap their tires after cleaning and they dry just to keep them clean and protected and allows you to move the car around if needed without getting dirty. We usually leave ours on until we race, meaning we leave it on when we push or drive the car thru tech just to keep them clean.Turn LEFT, Vote RIGHT!
Regular Saran wrap or any clear wrap isn't going to block UV at all. If that's your goal, wrap them in black plastic which is available. If you're trying to keep your tires safe from UV, keep them completely covered any time you're welding in the shop (if that's where you store your tires). Welding puts out crazy amounts of UV radiation even compared to the sun. Anybody that's ever welded without proper skin protection learned this the hard way. That is assuming they figured out that UV radiation (not visible light) is what literally burns your skin just in case the spatter didn't also get them.
Good post....I think it wont be long until we will be shrink wrapping them.Originally posted by Matt49 View PostRegular Saran wrap or any clear wrap isn't going to block UV at all. If that's your goal, wrap them in black plastic which is available. If you're trying to keep your tires safe from UV, keep them completely covered any time you're welding in the shop (if that's where you store your tires). Welding puts out crazy amounts of UV radiation even compared to the sun. Anybody that's ever welded without proper skin protection learned this the hard way. That is assuming they figured out that UV radiation (not visible light) is what literally burns your skin just in case the spatter didn't also get them.Turn LEFT, Vote RIGHT!
Somebody is *definitely* going to start selling "tire wrap" and charging a stupid amount of money for it, because other stupid people will line up to buy it.Originally posted by a25rjr View PostGood post....I think it wont be long until we will be shrink wrapping them.
See also : "Voltage booster for MSD ignitions ! 200% HP gains !"
I always shake my head at many racers, they treat the engine or some shiny part 10 times better then they do their tires. Tires are one of the most important things on the car, they need to be washed by the next morning and properly cared for and maintained/worked on or you might as well just race with the same tires all year.
Your tire program (not talking doping/cheating them) is a big key to being successful
Of all the great posts you post on here, this one has the most TRUTH ever.Originally posted by billetbirdcage View PostI always shake my head at many racers, they treat the engine or some shiny part 10 times better then they do their tires. Tires are one of the most important things on the car, they need to be washed by the next morning and properly cared for and maintained/worked on or you might as well just race with the same tires all year.
Your tire program (not talking doping/cheating them) is a big key to being successfulTurn LEFT, Vote RIGHT!
A little history to show how things change.It started in the late 90's, a tire dope company recommend wrapping after treating.You would remove the wrap,roll the tires across the driveway to get some dust on them,then hand rub it in to hide the shine that the treatment left.You would never let anybody see a tire wrapped.
Now days pressure wash ,hand wash with a non voc cleaner, wrap with a colored plastic.Make sure everybody sees your tires wrapped.
