Looking to buy a new j bar.I use a lot of Wehrs stuff and think it's top Quality stuff but that double adjuster on the j bar doesn't look that strong.Anybody use them and have good luck.Also looking at the BSB.
Wehrs j bar
The adjuster on the Wehrs bar has never been a problem, but the pinion end of the j-bar is quite beefy on the Wehrs. It will run into some lift bars and have to be ground for clearance so the j-bar doesn't bind-up against the lift bar. If you are using Wehrs aluminum lift bar and mounting brackets then it's not a problem.A droop rule is like infield tractor tires, everyone knows it's stupid, but they still keep doing it.
