Radiator relocation
  • HighWide&Handsome
    • Jun 2016
    • 3
    Radiator relocation
    With all the emphasis on fuel cell location, weight distribution, ballast placement and so on, why haven't teams relocated the radiator to the center/rear of the car?
  • jrkracing54
    • 620
    I think most rules state that the radiator must be mounted in the stock location. At least the rules I compete by say that. John 1*
    — Heraclitus
    • RacerX10
      • 571
      Not sure there would be a justifiable advantage either, with the dry sump and torque arm stuff already in the middle of the car.
      • Kromulous
        • 3008
        What if you layed it down flat, and made a duct of sort to the nose to create suction way out under the plastic nose?
        Weight down low, helps, and sucking the nose to the track bonus !
        Just say no...
          As others have said, not legal. I have seen it done back in the 80s.
          • talclipse
            • 738
            After cooking a couple motors a few seasons back Delmas Conley relocated his radiator to the deck. They used two large fans on the underside of the radiator (not sure if they were push/ pull). It lasted a week or two then they went back conventional.
            • DSD75
              • Feb 2015
              • 22
              Saw an open wheel years ago at Crossville TN with the radiator mounted behind the RR quarter panel. Guess with alcohol heat issues were minimal.
              • Krooser
                • Nov 2012
                • 3117
                Before most guys had a handle on cooling systems I saw tons of rear mounted radiators, twin radiators and even a 30 gallon water tank used to try to keep an engine cool and/or gain an advantage... most guys always go back to the traditional set-up.
                I remember one top notch sprint car guy even running two small radiators.. one on each side or the roll cage along side of his head!
                Class of 2019
