So last week I had a 500 on the left front... We won the feature, but the car was tight on corner exit on the gas as soon as I would pick up the throttle...Sometimes I would drag the brake off the corner to keep the nose of the car down till I could drive the push out. I have always thought that a softer LF spring loosens the car off the corner and of course stiffer LF tightens off. So this weekend all I did was soften the LF to a 450. Everything else the same...Same track conditions...The car had a terrible throttle push all night. 10 times worse than the week we won?? It was undrivable. I could enter the corner perfect, have the car turned to come off, but as soon as I would pick up the throttle the car would take off to the wall...Should have changed it back, but I didn't. So my question is...Did I go the wrong way with this spring?
LF Spring Theory
The more you soften the LF the more you will tighten exit. The days of saying it doesn't really effect exit are gone.
It will free your entry. However it has another effect that the closer you match the front springs the better the car will turn in on its own. I like to keep dropping the LF spring until it makes the car to free on entry then step it back up 25lbs.
With that logic a 525-550 LF spring will help eliminate your throttle push! 50# less LF spring is not going to turn your racecar into a dump truck. Way Too little info to give any kind of responsible recommendation. I'd bet the track had more moisture in it, that tends to make these cars a tick (sarcasm) tighter.Last edited by CCHIEF; 06-14-2016, 10:51 PM.
He was already throttle tight the weekend before and lowered the LF spring even more so yes 50 pound would make it worse and possibly make it drive like a dump truck
The LF spring is not the go to adjustment for a tight car on exit. Give up what you got car, set,track and tires. Their is so much dynamic wedge in these cars when hiked up that 50# of spring... on the least loaded corner of the car (on exit) is not where you want to be adjusting FOR EXIT! Bringing the LR bars closer together @ frame would be a much more viable adjustment.
