bert trans
  • jcagle44
    • 325
    bert trans
    bleeding the clutch and not getting any kind of pedal i am getting fluid not much pressure does it sound like the master cylinder is bad
  • jrkracing54
    • 620
    I had the same issue with the #4 line that came with my car. Switched to a #3 line and fixed the problem.
    "Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back."
    — Heraclitus
    • LIS20
      • 83
      Bert
      I have the same problem -- good pressure and peddle at the master cylinder --good pressure and peddle at the end of the lne -- hooked line to BERT, fluid came out of the bleeder but no peddle. I sent the BERT to the rebuilder and everything was fine.
      I did notice that when I let the line gravity feed, nothing came out after an hour or so.
      Will try a -3 line. Any other ideas would be appreciated.
      • JAMESGANGRACING
        • 192
        It can take forever sometimes,let it gravity bleed for a while then take the bleeder plug out, put your finger over the end and pump the pedal, releasing the pressure at your finger and pretty soon it will work,then put the plug back in.
        • stevo
          • Jun 2008
          • 622
          Put rubber hose over bleeder and run into bottle so air does not get in line and pump away
          • late96
            • 581
            We found it to be easier to unbolt trans and rotate so bleeder was up. JMO
            • vms
              • Mar 2011
              • 84
              same brake bleeder was used to fix it
              i two had the same problem, the first thing was i had a 5/8 bore master cylander and i changed that. I do have a #4 line and your right the pressure dont seem normal and i could get anything to move to the tranny. So i bought a brake bleeder rigged it up and it worked on bleeding. Then we didn't relize how the latemodel clutch worked and was trying to us it like a car clutch. Now it works all the way to the floor. But the bleeder cost 20 bucks from harbor frieght. autozone it was $30. But it worked.
