Power steering pump or rack going out ?
  • Dirtmod13
    • Jan 2014
    • 245
    When I turn the wheel at 1500 rpm idling, belts squeal, even when revved to 5,000 still difficult to turn wheel but it'll turn with my help. Any ideas?Never had a rack go out so not sure of what the symptoms would be.
  • Dirtmod13
    • Jan 2014
    • 245
    We run the head/ block mounted power steering pump.
      Could this be as simple as the belt being loose?
      • Dirtmod13
        • Jan 2014
        • 245
        No, we tightened it to point that's it's too tight.
        • mod88s
          • 226
          Is that what was making it squeak or did you figure out what it was?
          • Dirtmod13
            • Jan 2014
            • 245
            Waiting to swap the pump out and check it.
            • CCHIEF
              • Jul 2014
              • 399
              Is the belt wore out(bottoming in pulleys)? V belts, if that is what you have, run off the sides.
              • Dirtmod13
                • Jan 2014
                • 245
                Nope, new belt/ pulleys, 1 race
                • CCHIEF
                  • Jul 2014
                  • 399
                  P/S problems can be a itch to figure out . Without T-ing gauges in gauges its a expensive game of logic and replacing parts.Because the belt squeals it would seem to be a restriction somewhere. Some times hoses fail internally with no signs on the outside. Any more info? How did it start, Any wheel contact? Squeal while turning one direction,both directions or no turning at all?
                  • ALF401
                    • 164
                    If you have air in the system it will act like that as well. Bleed the system a couple times to be sure. See if that helps.
                    • Dirtmod13
                      • Jan 2014
                      • 245
                      We decided to install the wider vbelts 13 mm vs 10/11mm,Squealing stopped. Must have been bottoming in one of the three pulleys. They ride a bit high now but better than what we had. Thanks to all that posted.
                      • CCHIEF
                        • Jul 2014
                        • 399
                        You got to the problem... cheap.
                        • Lizardracing
                          • 839
                          For whatever it worth belt are supposed to ride a little high in the groove. See picture.
