Originally posted by RCJ
View Post
Preloading LR
I will agree to two statements:
A heavier spring will catch the weight faster.
A heavier spring will unload weight faster.
We need to start thinking of a spring as a timing device just like a shock. At what point do you want maximum weight transfer and how much movement do you want at that corner. A shock is a hydraulic spring while in motion. Stiffer compression equals stiffer spring. Stiffer rebound equals softer spring, while in motion or dynamic state. So the combination of spring and shock determine when that corner catches the weight and when that corner releases the weight.
I disagree. A stiffer compression shock will not make that corner of the car catch more weight. Just the opposite...it will slow down the transfer of weight to that corner which will have the same affect of that corner having a softer spring but with less travel.Originally posted by lindsey97 View PostI will agree to two statements:
All comes down to forces involved. If the RR had a 20#/in spring, adding a really aggressive compression shock would at least add some loading during chassis roll.Originally posted by Matt49 View PostI disagree. A stiffer compression shock will not make that corner of the car catch more weight. Just the opposite...it will slow down the transfer of weight to that corner which will have the same affect of that corner having a softer spring but with less travel.
But in general, I agree.Modern Day Spec Wedge Racing
Mastersbilt racer probably said that better. But exactly, the shock doesn't catch any weight. it adjusts the time it takes for a spring to catch or release the weight. But while in motion does add some spring rate, maybe it is negligible as to the amount. I still believe we need to look at the spring as to when we catch the weight, not just heavy spring gets the weight.
What I am saying is, if your shock is #150@ 1 inch/sec, and that is the velocity, the shock is indeed applying 150# the same as if a 150# spring were compressed 1".Originally posted by lindsey97 View PostMastersbilt racer probably said that better. But exactly, the shock doesn't catch any weight. it adjusts the time it takes for a spring to catch or release the weight. But while in motion does add some spring rate, maybe it is negligible as to the amount. I still believe we need to look at the spring as to when we catch the weight, not just heavy spring gets the weight.Modern Day Spec Wedge Racing
Just when you think you e figured it out you throw more equations into everyone's heads. Haha we just had this discussion on a street stock adding more compression and it tightening up the car all the way around on the rr. I argued saying it wouldn't but you never know with velocity and how many pounds per second.
Put does a shock load the 150 # static? or only when moving? via the dampening.
I know once compressed 2 say 2" there is increased rod pressure from the Gas, but does that equal the 150lbs or does it decrease as the movement slows or stops?
Just say no...
A shock only applies force when it is moving. The exception being the rod pressure, which is nearly constant more or less. It increases some, depending on shock design.Originally posted by Kromulous View PostPut does a shock load the 150 # static? or only when moving? via the dampening.
I know once compressed 2 say 2" there is increased rod pressure from the Gas, but does that equal the 150lbs or does it decrease as the movement slows or stops?Modern Day Spec Wedge Racing
Lindsey97, just emptied my pm box. Try me again.Originally posted by lindsey97 View PostMastersbilt racer probably said that better. But exactly, the shock doesn't catch any weight. it adjusts the time it takes for a spring to catch or release the weight. But while in motion does add some spring rate, maybe it is negligible as to the amount. I still believe we need to look at the spring as to when we catch the weight, not just heavy spring gets the weight.
