Where can I purchase some shims for a Quartermaster reverse mount starter? Thanks
starter shims
More info needed I would think?Originally posted by eskew11 View PostWhere can I purchase some shims for a Quartermaster reverse mount starter? Thanks
Do you have a direct drive QM bell-housing? Meaning there isn't a idler gear like the berts, brins, and ETC bell-housings
If you have one with a idler, you shim the flywheel back to get the proper clearance not the starter. No idea if you have the QM direct drive as I've never owned one but don't think you shim the starter anyways as it should be set by machining the bell-housing but depth could be set with shims just like the other bell housings so I'd guess you shim the flywheel also.
http://www.speedwaymotors.com/Bert-T...ate,57688.htmlOriginally posted by eskew11 View Postyes it has the idler gear
or
http://www.speedwaymotors.com/Bert-T...evy,57687.html
Lots of places sell them, not sure how many list the different thickness as there used to be different thickness's available not sure anymore.
