drop spindles VS standard spindles
  • racinrocket1
    • 257
    ok now I know the difference before everyone jumps me here but other thank just raising the car what other changes does the drop spindles make to the front geometry or is there no change since your just raising the chassis the same amount ? also could you get away with running a drop spindle on the Rf and a standard spindle on the LF ? thanks for the info
  • RacerX10
    • 571
    i called rocket about them before i purchased a set. they told me there isn't any appreciable difference at all other than getting your front end 1/2" up off the ground.
    you'll need to do both sides.
    • Punisher88
      • Nov 2014
      • 495
      Only adding one on the Rf will be like preloading your spring an extra half an inch but without actually changing your control arm angles. It would drastically increase bite I would assume.
