Tire Machine
  • Hammerdown51
    • Aug 2013
    • 17
    Tire Machine
    I've been working on building a tire machine and I have the base all done but I have hit a snag in the project with the motor. I had a 1/4 horse electric motor that I was going to gear down using a bunch of sets of bike gears but that's proven to be way too much work. For those of you who have built your own tire machines; what motors/ transmissions did you use to make them? I've heard people use cement mixer motors but I don't own one and it seems like a waste to throw the rest of it away
  • RCJ
    • Nov 2007
    • 509
    That is the problem everybody has ,finding a cheap low speed motor.I found one on ebay ,worked for a month then stripped.I have 12 volt electric jack on my trailer, this winter I'm going to take it apart and see it will work.
    • JustAddDirt
      • 1893
      looking at my Liftmaster garage door opener when I installed it, got my mind to wandering. Its an 8500 series torsion bar opener.
      goes both directions.
      moves slow
      1hp. motor
      If I hadn't bought the All-star Performance motor and gearbox, I would have pursued it.
        • 14322
        You can buy gear reduction boxes for typical 120V electric motors for less than $100.
        • Hammerdown51
          • Aug 2013
          • 17
          Do you know a good website to find a gear reduction box on? I checked on ebay before I posted this like RCJ said but having it strip out is a possibility when buying on ebay.
          • stock car driver
            • 3233
            all star sells the motor its the same one cpd and most everyone uses
            • a25rjr
              • 3774
              I buy my motors for my rotisserie from Graingers. They sell many different models depending on your application.
              They are usually around $100.
              Turn LEFT, Vote RIGHT!
