got the first of two cars on the scales last night. we were able to create a starting point of 48% cross, 53% left and 53% rear total weight 3345. class req. 3200 minimum.. question is, how can i get the total weight down w/o compromising the percentages??
leaf car questions
2" backspace wheels on both front tires and left rear. 1/2" spacer on left rear 1/4" spacer on the left front . 3" backspace on RR. 225/70r15 tires on left side. 223/70r15 right side. 25lbs in right side tires, 17 lbs in left side. 1" lowering block on both left and right rear. this is our basic dry track main event set up. 12 gallons of fuel.Last edited by Wrenchead84; 03-02-2017, 12:39 PM.LEAF SPRING NATION!!
look for 100 ways to remove a pound instead of 20 to remove 5. Stock cars have a lot of needed sheetmetal.Originally posted by Wrenchead84 View Postgot the first of two cars on the scales last night. we were able to create a starting point of 48% cross, 53% left and 53% rear total weight 3345. class req. 3200 minimum.. question is, how can i get the total weight down w/o compromising the percentages??
OK I HAVE NUMBERS TO POST, on the second car. this one is not a new car. just finished doing a back half. total weight 3350lb. left percentage 54%. rear percentage 51.3%. cross 51.7%. bite 194lbs. this is with 25lb of air in both right side tires 15lbs in LF. and 17lbs. in LR. 2" offset wheels on fronts and LR and 3" offset on RR.LEAF SPRING NATION!!
in response to this car. car drove great. its a crate motor car so it had good traction and nice pull out of the corner. handled really nice. i wont be the regular driver so i will these this one be as the reg driver is new to the classOriginally posted by Wrenchead84 View Postgot the first of two cars on the scales last night. we were able to create a starting point of 48% cross, 53% left and 53% rear total weight 3345. class req. 3200 minimum.. question is, how can i get the total weight down w/o compromising the percentages??LEAF SPRING NATION!!
this car drove in decent but was loose off. we ran the setup above with 1/4" spacer in LF and LR.Originally posted by Wrenchead84 View PostOK I HAVE NUMBERS TO POST, on the second car. this one is not a new car. just finished doing a back half. total weight 3350lb. left percentage 54%. rear percentage 51.3%. cross 51.7%. bite 194lbs. this is with 25lb of air in both right side tires 15lbs in LF. and 17lbs. in LR. 2" offset wheels on fronts and LR and 3" offset on RR.LEAF SPRING NATION!!
