Is a 87 caprice a good car to use for a race car. Or would you go with a 92 caprice/impala ss body style
caprice
My Pro Stock/Super Stock/ Sportsman is also a full size GM Caprice, Impala, Coupe DeVille type chassis. 65" rear end and does very well out west in Cali.
They are a much wider platform.
which makes them more stable in corners.
bump steer is way better than a metric from factory
you can put ford crown vic front a arm. or arms on the lowers to make it 1" wider per side.
little bigger so they are a tad heavier, but stronger as well.
All mid 70's GM full size a arms will fit.I think there should be lifeguards in the genepool.
