spherical leaf spring bushing
  • Wrenchead84
    • Nov 2016
    • 43
    has anyone tried them? seems like a good way to keep the tire planted flat?
    LEAF SPRING NATION!!
  • Krooser
    • Nov 2012
    • 3117
    I have a leaf super..the Po said he tried them but rubber worked better
    Class of 2019
    • 95shaw
      • Nov 2007
      • 205
      A friend used them in a half leaf late model. Of course with a panhard bar, there's a lot of lateral movement. He felt it helped free some of the bind.
      On a full leaf, because the spring is trying to twist, can change some of the effects. What works for one may be a curse for others.
      • dirtrace09
        • Aug 2007
        • 746
        When I raced leaf spring modifieds, I ran them when I ran composite leafs. They worked well in that application. I tried them with steel leafs but found rubber bushings to be much more consistent. Like 95Shaw said, it may work for one.
        • Wrenchead84
          • Nov 2016
          • 43
          Seems the rubber bushing does well enough, ill put money elsewhere. thanks
