Motor combo
  • SRT17
    • 172
    Motor combo
    Our track has opened up the rules some this year. Any Hyd. cam any carb and roller rockers. What would be a good starting point? 3/8 mild bank 2900# 3 link. Thanks
  • dereksehi
    • Jun 2013
    • 307
    What kind of heads are you allowed to run? Can you run headers? Is there a RPM limit or what do you typically run for RPM? Can you run a hydraulic roller or must it be flat tappet? What about compression are you limited there or not?
    • SRT17
      • 172
      Running WP 052 76CC heads...Headers 3 1/2 outlet... I turn 6200-6500 rpm.. 7101 intake.. 4.030 bore Hyper 4 EB pistons..Hyd. Flat tappet....No roller cams just roller rockers....No compression rule..Also stock single valve spring with dampner...I use the z28 springs...Thanks
      • dave41
        • 208
        headers to large
        • SRT17
          • 172
          Chassis Headers 1 3/4 tubes with muffler and turn downs...
          • Confused?
            • Apr 2009
            • 418
            Headers are too big for that combo and rpm range.
            • stock car driver
              • 3233
              What is your question? If your wanting to know what a person would build for those rules it would depend on your budget...
              I wouldnt use those wp heads unless they were mandatory or heavy hyper pistons whatsoever.
              • SRT17
                • 172
                I am looking for advice on cam size and carb cfm. I run the isky lr3 and 600 holley now. Does good when I can get the car to hook up..I won a few last year. So I know what I have can win...My machinist said to stay with the cam and get 1.6I 1.5E roller rockers....Just seeing if any one had any better combos... Don't want to get out motored....LOL also those heads or stock...Thanks
                • stock car driver
                  • 3233
                  ic, by reading your first post it sounded like the rules you posted were the only rules... not what was changed.
                  your motor would run like a whole different engine with some decent forged pistons, even basic mahle pistons are hundreds of grams lighter than yours and use much thinner rings.
                  If your having trouble hooking your car up as you say go to a wider lobe separation so the power is smoother and hits easier, it will also give you a wider operating rpm.
                  • SRT17
                    • 172
                    Sorry for the confusion...We can only run cast or Hyp pistons. I am most of the problem with it not hooking up...LOL I have a BAD habit OF WANTING TO MATT IT TO THE FLOOR coming out of the turns....That is why I went with the bigger tube headers, trying to move the power band. I was also looking at changing the intake to like an air gap...
                    • CCHIEF
                      • Jul 2014
                      • 399
                      Get a 200# throttle return spring!
                      • SRT17
                        • 172
                        Talked to Isky they suggested the 292 Mega hydraulic cam. .505 lift 1.5 roller rockers with a open intake and a 750 holley
                        • stock car driver
                          • 3233
                          isky doesnt make anything worth buying, 1960s technology
