Relocating shocks
  • Nate85
    • Mar 2017
    • 2
    Relocating shocks
    Relocating shocks on 85 monte street stock. Not exactly sure where or how. Some pics would give me a great idea. Or some basic instructions. I know the mount to front of. Lower a arm. But not exactly sure. Rear. Has a ford 9. Not sure where to locate these either. Pics would be greatly appreciated on this as well. What would be better. Bolt on mounts or weld on. Placement of these would be helpful also thanks
  • klv8lm
    • 185
    You want the lower mount to be about 7" below axle centerline. usually mounting to the back of trailing arm mounts is good.
    If your driving on the edge, you are trespassing on my property!!!
    • speedbuggy
      • 259
      Walk through the pits and looks at metric chassis modifieds that have to run stock lower control arms. That will show you how to mount a shock outboard of the spring in the front.
      Where you mount the shocks depends a lot on why you are relocating from stock position and what you are trying to accomplish, which you don't mention.
      • Renegade Cust Susp
        • 349
        Pics are in a mod but same principle applies
        Broc Burton
        go.fast.crs@gmail.com
