right front cut-off
  • mclendon
    • Jan 2010
    • 60
    right front cut-off
    using a ball valve ,can i tee off the line coming from the master cylinder for the front brakes, run it to the ball valve then out off ball valve to the right front brake or is there a certain way it has to be done ?...... thanks
  • RCJ
    • Nov 2007
    • 509
    I know everybody uses a r/f shut off, but I always have trouble with them. When you hit the brakes and have 600psi of line pressure the shut off will bleed a little bye. After doing this for several laps the r/f will start dragging.
    I went to a caliper with a small piston and then added a lever style proportioning valve.
      • 2020
        • 2020
        This allows any bleed thur that might happen from the ball valve and will return the pressure thru the one way valve and keep the RF from applying.
