Wheelbase
  • HMS27
    • May 2011
    • 57
    Wheelbase
    What's everyone's opinion on wheelbase?
    Division I run in allows a 101 inch wb.
    Pros and cons of a 101 inch wb versus a 108 inch wb?
    If your not racing on dirt it's your on asphalt!
  • 7uptruckracer
    How do they allow you to shorten it? Just putting short rear links in the back won't necessarily be good.
    • hogracer3d
      • 511
      we shortened a 108 car down to 105 ( but we did a bunch of other stuff too) and it made the car less user friendly, more susceptible to dialing yourself outta the park with adjustments.
      but again, not sure that the wheelbase was all of that.
      That being said, I would have probably left it at 108, if I were doing it again
      • HMS27
        • May 2011
        • 57
        We can shorten it any way we would like but I can't decide if I want too.
        • fastford
          • 4059
          108 to 101 on a heavy cars means the world as far as rear weight percentage goes and we cut our frame at the front where the side rail welds to the box....
          • JustAddDirt
            • 1893
            shorter wheelbases are a lot more twitchy, and darty. unless you can totally re-do the front suspension, and are allowed a lot of aftermarket parts.
            stock stuff will have way too much bump steer, and other front end problems for the car to drive smoothly with a short wheelbase.
            I would not go under 108 if it were me.
            • HMS27
              • May 2011
              • 57
              The front has already been changed to aftermarket upper A frame Towers and tubular A Frames. If it is shortened I think we decided not to go less then 104.
              • fastford
                • 4059
                you need to check your bump steer no matter ehat kind it is or how long or short it is....
                • JustAddDirt
                  • 1893
                  point & shoot
                  are you running stock upper a arm mounts, in the stock location?
                  agree with you fastford, on bumpsteer.
                  • stock car driver
                    • 3233
                    101 for a dirt car no way
                    for a pavement car absolutely
                    • fastford
                      • 4059
                      with the engine set so far forward on a street stock , I,m curious why you dont think it will work SCD ??
                      • stock car driver
                        • 3233
                        Small window to get the set up right....
                        Dirt tracks are always changing ANY you want as big of a set up window as possible, period.
