Short bar on a leaf spring car?
  • chevy370lsx
    • Mar 2011
    • 50
    Just setting here thinking of some off the wall things. Since my rearend slides over in the corners quite a bit I just had a random thought of running a short panhard bar on the left side, my gear already has a short bar/j-bar mount. Any one ever tried it?
  • JustAddDirt
    • 1893
    probably would want the bar as long and flat as possible, that way it doesn't bind up the springs.
      • 14307
      Very difficult to impossible without binding the springs.
      • a25rjr
        • 3774
        Don't run one too short and with a lot of angle. When you get off the gas, it will make it very twitchy.
        Turn LEFT, Vote RIGHT!
        • over4T
          • Feb 2015
          • 1084
          If your rear leaf mounts are spaced wider than the front mounts you shouldn't need such a thing. Like MBRacer said it's very hard to do with any success.
