Rr spring mount on chassis
  • Hammadown
    • Sep 2018
    • 9
    Does it matter how high the weight jack mount is on the chassis on the rr?
  • RaceEngineer
    • Oct 2018
    • 482
    What matters is the height of the upper spring perch.
    • racing08
      • Jan 2018
      • 49
      So do you want the rr spring perch high or low in the chassis?
      • over4T
        • Feb 2015
        • 1103
        Depends on if you're running under IMCA type rules that say rear springs are to be on top of the rear end. If not we like them low.
          Anything besides getting ride height set correctly? Some software designers have said for years it affects weight transfer.
          • RaceEngineer
            • Oct 2018
            • 482
            Indeed it does.
            • Hammadown
              • Sep 2018
              • 9
              I run my rr on top, so if I went from say a 13 to an 11 inch spring it would transfer more or is it where the jack bolt is mounted on the frame that matters
              • stock car driver
                • 3233
                lr high rr low
                wt jack bolt doesnt matter as has already been said, the top spring cup height will matter and make a noticeable difference
