My frame is bent right behind the crossmember. Measuring a 1/2" off by measuring to the side frame holes to the center hole of the crossmember.Is it trash? Leaning towards clipping it but I've never clipped a metric Monte, anyone have any tips if I go this route?
Bent frame
Where you from? Start asking around for a frame shop that works on race cars. They can fix cars that are bent bad, and it sounds like yours inst that bad.Originally posted by WOT114 View PostMy frame is bent right behind the crossmember. Measuring a 1/2" off by measuring to the side frame holes to the center hole of the crossmember.Is it trash? Leaning towards clipping it but I've never clipped a metric Monte, anyone have any tips if I go this route?
If they do a lot of race cars they will be able to tell you right away if they can get it straight and they usually dont charge much. Ive had 2 frames fixed and both times it was less then 200 bucks.
If the frame is not badly crinkled anywhere, a good frame shop can fix it. The fix may involve first cutting some of the cage loose from the frame, and then re-attaching the cage once the frame has been straightened. Look for a frame shop that does frame straightening on commercial trucks. These guys usually know what they are doing.
Check everything over is it in a critical area .If wheel base is off can you slot lower control arm holes to correct it.1\2 inch is not a lot considering how much beating and banging these cars do. I have had cars bent that worked better bent than straight just some food for thought.
I had a metric pure stock bent back 8" in the same place. My local friendly body shop pulled it for $100.00 and got the wheelbase within 1/4" of spec.
Truck frame shopsdo stuff like this everyday...Member of the Luxemburg Speedway Hall of Fame
Class of 2019
