i have two questions
first one, by changing tire type on your car will that play a part in getting different numbers out of your caster/camber settings. we went from a 245,255 hoosier dirt boss to a hoosier imca g-60 tire. checking the front end setting yesterday all the number were different then we had a couple of races ago when we set it last. haven't hit anything during the races. also what are some good front end setting numbers, mainly larger type tracks with slight banking.
numbers now
rf camber -3.9, caster 3.2
lf camber 2.1, caster 2.5
question two
what would be a good split valve shock for the right front, spring is a 925lbs, 3000 lb car, we have a entry mid corning push, its really bad we he qets back on the throttle. right now we have just a 5 vavle in the rf we have tried a 6 and a 7 also. the left rear shock is a 7/2, lf is a 5/2, and rr is a 5. will it matter having most the shock split valves?
numbers now
question two
