Cooling issues
  • dove14
    • Nov 2010
    • 20
    Cooling issues
    What would cause me to be pushing water out at 180 degrees? It keeps pushing water out till the water is too low and then it runs hot. It does the same thing every week. It shouldn't be pushing water no hotter than that so im wondering what would be causing it? Thanks in advance on any ideas.
  • ToddSmith16
    • 2854
    I would say head gasket as problem #1 or a faulty temp gauge which would bring other problems into question. What is the rating on the radiator cap?
    • dove14
      • Nov 2010
      • 20
      28 to 32 lbs.
      • Egoracing
        • 4852
        Originally posted by dove14 View Post
        28 to 32 lbs.
        How old is the cap and has it been cooked? If it is over a year old or has been run hot I would replace it.
        • dirty white boy
          • 1238
          if gauge ant messin up,...head gasket or a crack....bare in mind,...water dont boil till 212 degrees.....
          white trash motorsports
          • dove14
            • Nov 2010
            • 20
            Thanks for all the ideas. I've tried 3 different gauges, and I've changed the radiator cap 3 times.
            • race21j
              • 3165
              NAPA sells a unit that you remove the rad. cap and place this over the cap area and if it changes color it indicates combustion in the water. May save a tear down.
              Fought the same thing for about 2 weeks. Bad head.
              • dove14
                • Nov 2010
                • 20
                Thanks alot. I'm willing to try anything now.
