Need help with mini-starter
  • Dirtman29
    • 1690
    Trying to get the SS done, now having starter issues. Mini starter on a 406, using a flexplate. The teeth of the starter are always just touching the teeth on the flywheel, making a awful metal hitting metal noise when it starts. Tried shims, did not work. Its as if the starter gear is too long. Flywheel is facing correct direction. Any suggestions?
  • 21 racer
    • Dec 2007
    • 74
    they make shims for the starter head moves the gear back they came with my starter when i bought it
    • bushracing67
      • Oct 2007
      • 904
      http://cgi.ebay.com/ebaymotors/JEGS-...ehicleQ5fParts
      the two shims on the right are what you need
      • Dirtman29
        • 1690
        Thanks guys, never had to shim them years back & I forgot they did come with those shims (this starter was on the car when I bought it). Found someone locally that had them, works fine now!
