Camaro Floater
  • gadirtracer
    • 1039
    Camaro Floater
    What width floater is common in a '70 to '81 Camaro? 60" or 62"? Does anyone have a side to side measurement? Like from rotor to leaf?
    Running 8" wheels and 8" E-Mod tires, with 3" offset wheels all the way around the car.
    Gill T. Azell
  • stock car driver
    • 3233
    61.5 is oem width
    • dirttrackrocker
      • Nov 2010
      • 664
      I ran a 60" and had a 4" on the RR and didn't have any problems.
      • bushracing67
        • Oct 2007
        • 904
        personally i would run a 62 with a 1" spacer on the lf and a 2" spacer on the rf... wider is better
        • little302
          • Jun 2009
          • 94
          GM had that widetrack figured out waaay back when!!!
          • DaveBauerSS6
            • Jun 2010
            • 566
            60 inch for the Camaro. Go wider and you will have a loose in car. You will want that RR in tight to the leaf. The rotor to leaf measurement is going to vary on manufacture. Setup everything, then weld it in. It all fits.
            Gator Engineering
