tire temps
  • shadowj38
    • Jul 2011
    • 161
    tire temps
    i run american racers and im having trouble deciding when i should put the sd 38's on instead of the sd 33's. i was wondering how high of a temp you can run a 33 and for how long before it will start to "go away". any help of opinions will be appreciated. thanks
  • 4bangerhotrod
    • 374
    prob be better to ask this question in the LM section. but i dont like to run the 38 on a hard dry track,
    • bushracing67
      • Oct 2007
      • 904
      personally i would take all the 38s you have and put them in a big pile along with a gallon of gas and a match, just run the sd44 on the rr, 90% of the time if your running 15 laps you will want rr 44, lr 33, rf 23 or 33, and lf 23 will be good, i have a few instances where a rr 48 was in order, but its a gamble if your running under 20 laps, if its still tacky use a 33 on the rr
      • shadowj38
        • Jul 2011
        • 161
        i run a 20 lap feature but its usually a gamlbe deciding because some weeks we have run green to checker. then other weeks we get a 2 or 3 lap run before a caution comes out. how can i prep a 44 to come in quick in a case like that?
        • bushracing67
          • Oct 2007
          • 904
          i just run a foam mud plug, typically a 44 will fire just as fast as a 38, i prefer the lsw block tread
          • shadowj38
            • Jul 2011
            • 161
            thanks ill give it a try
