if you have the lr arm level and the rr arm up hill its definitely going to drive off the corner sideways! LOL
Lower rr trailing arm metric
Are you talking about the lower rear tariling arms ? Do you want to keep them straight instead of having any angle in them ?Originally posted by outlaw087 View Postif u r on the gas when rear end rotates the bars ( angles down ) pulls up on frame taking weight off the rear end. if the bars ( angles up ) pulling down on the frame it keeps wight / bite in. does this help
I was talking about the top arms. I have my lowers level. all of my mounts is adjustable and on tubs and rod ends. all of the mounts is in the stock location.Originally posted by Ricky76 View PostAre you talking about the lower rear tariling arms ? Do you want to keep them straight instead of having any angle in them ?Last edited by outlaw087; 09-08-2011, 04:59 PM.
So you're saying run all rear trailing arms straight ? Right now my top ones are straight, but my lower ones are at a big angle. The lower ones that have the mount on the bottom of the rear end housing are 4 inches from the bottom of the rear end housing. Should I change them and run them straight ?Originally posted by stock car driverNo I dont agree.
The closer to level all 4 arms are the lower the rear roll center which promotes side bite and the more consistant your pinion angle, rear steer etc will be in and thru the complete corner.
My old chevelle had all 4 level which many claim on here will bind etc. that car had more fwd drive than my metric by a long ways, it lacked in side bite but it was 6 inches wider track also which I attribute the lack of side bite to.
The reason guys think more angle adds traction is they FEEL the tire drive up under them and lift on the car, so they FEEL they have more traction, what they have is more traction while its on its way up but once its under there you LOSE drive and traction and have to feather the throttle to get the rest of the way off the corner.
A car with the lf arm down and rr up drives off the corner sideways, when your behind those guys you can see their door numbers on the drivers side and their whole lf tire... thats never the fast way around a track.
Thanks for the information. My rr ride height is 9 1/2 and my lr is 9.Originally posted by stock car driverI run my lowers as close to the housing as possible ALWAYS...
You must have a really high ride height as I cant get my uppers to 0 degrees.
I'd like to try that, but our track is a very small and very tight 1/4 mile that gets really dry slick. I'm thinking if I only run 51-52% rear, it won't have any forward bite. You have to slow down so much in the turns because the corners are so tight.
Originally posted by Ricky76 View PostI'd like to try that, but our track is a very small and very tight 1/4 mile that gets really dry slick. I'm thinking if I only run 51-52% rear, it won't have any forward bite. You have to slow down so much in the turns because the corners are so tight.
I run a mustang hobby (unlimited motor rules with stock suspension) and never go above bout 52.5 rear. The rear suspension on the mustang is pretty much same as a metric
stock car driver you said you run no lead out side or behind rear springs but your pictures shows lead outside of left rear weight jack and you run 200 lb of bite because your left lower is level .if you would put some angle it it you could back that bite off. angle in left lower will permote drive at left rear and yes angle in right will lossen it some into the corner only wile off the gas
Will angle in the right give you more off the turns or should it be level for more out of the turns ? I see what you're saying about it being loose getting in while off the gas. I have both my lowers at an angle and my car is very loose entering the corner while I'm off the gas and I only run about 80# of bite in the left rear.Originally posted by racingford View Poststock car driver you said you run no lead out side or behind rear springs but your pictures shows lead outside of left rear weight jack and you run 200 lb of bite because your left lower is level .if you would put some angle it it you could back that bite off. angle in left lower will permote drive at left rear and yes angle in right will lossen it some into the corner only wile off the gas
