I run a 84 Monte and seems to be tight on entry pushes in mid turn & and loose on exit. The entire chassis is stock and nothing has been cut or moved, in our class we have to run a OEM stock chassis, no weight jacks or brake adjuster all stock. It has LF 1100 RF 1000 LR 200 RR 175. The track is 1/4 semi banked track and goes dry slick at the end of most nights. Pro Adjustable stock shocks all the way around with Hoosier asphalt slicks #2045 on a 8" rim w/2" offset all the way around, usually on lf 11 rf 15 lr 10 rr 10 with 3/4" spacer on RR and 1" spacer on LR. Probably about 100 lbs of lead directly above the rearend & evenly spaced across the rearend. The car is new for the 2011 season & it has several feature and heat race wins you can view on Youtube at http://www.youtube.com/user/3DInterceptor for IN CAR CAM and grandstand videos to possibly help for setup ideas.
What ideas can you give to help with the setup problem...???
