Just curious if anyone has experimented and had success or failure with a really long mount on the left rear bottom trailing arm, getting the connecting point as far away from the housing as possible; while using a stiff spring (11" 300lb) or a tall soft spring (16" 175lb), or stacking springs? The goal in mind would be to keep the LR planted for drive off. Thoughts? Harsh remarks?
Bottom Trailing Arm Question
Its ok i run the multi hole mount on the lr when u put it on make sure u dont put 2 much lead n the lr it will make the car to loose & u will lose some drive of but u dont need a lot of angle n ur arms u can get what ur lookin 4 out of shocks & springs i run mime bout levelDemon Chassis
