spring buckets
  • superstock_53
    • Oct 2009
    • 54
    spring buckets
    what do you think can i run spring buckets with adjustable cups or not here are the rules for the rear sup ALL COMPONETS AND MOUNTS MUST BE STEEL UNALTERED, APPROVED OEM. STEEL BUSHINGS ALLOWED INDEPENDENT REAR SUP ARE PROHIBITED, ADJUSTABLE SPRING SPACERS ARE PERMITTED SCREW JACKS AND WEIGHT JACKS ARE PROHIBITED.. what you guys think.... i think i can run a spring bucket
  • dirt daddy
    • Oct 2011
    • 34
    I would say no but thats me get u some wheel spacers or somethen like that 2 put under the spring u can do the samethang with thos as a bucket & b legal
    Demon Chassis
    • dirt daddy
      • Oct 2011
      • 34
      O wow i must of blinkd while readin the post sorry it does the bucket is legal
      Demon Chassis
      • superstock_53
        • Oct 2009
        • 54
        i all ready run the adjustable spring spacers.. i was just thinking for putting in a spring bucket so i could run a taller spring.... the rule is kinda of iffy
        • dirt daddy
          • Oct 2011
          • 34
          How tall r u wantin 2 go & what kind of car do u have
          Demon Chassis
          • superstock_53
            • Oct 2009
            • 54
            i run a monte carlo street stock stock shock mount on a ford 9in... on the left side im at at 10in spring with no adjustable
            • dirt daddy
              • Oct 2011
              • 34
              A 10" spring thats pretty short was they cut but i would put 13" springs n the back 11" n the front u might need 2 move ur shocks on the rearend up a lil 2 keep ur shock travel ok
              Demon Chassis
              • superstock_53
                • Oct 2009
                • 54
                right but the spring pocket has been moved down some cause in the right i can put a 10 and adjust if fine... also we used to run ashpalt and i all ways ran a 8 in on the lr and a 10 on the rr.. i do have adjustable spring spacers in.. so i was just thinking on runing aspring bucket
