tips for building factory stock camaro?
  • fsnewbie
    • Dec 2011
    • 2
    Hey guys new to this kind of car and have a bunch of questions. Rules are what I think pretty strict. factory floors front to rear, 360 cubic inch, factory intakes (no holleys), g-60 tires, torque converter or 10.5 clutch, stock driver location, stock brake pedals with no mods, no added weight, 3 degrees of pinion angle and suspension has to be in stock mounts.
    I have a mid 70's camaro already caged and gutted as much as possible. Was wondering about spring selection, shocks, steering box etc.
    Track is 3/8's medium banking, dry slick and dusty by end of heats. Thanks for any help you can provide.
  • RCJ
    • Nov 2007
    • 509
    r/f 1000 L/F 900 R/R 175 L/R 200 is a starting piont.Bilstein stock mount shocks.If the motor is not real powerful 50% rear 53 l/s
    • fsnewbie
      • Dec 2011
      • 2
      thanks for the advice. went a little stiffer on front springs based on local guys setup. same on rear springs. i'll try to end up with the percentages where you suggest, thanks again.
