metric car setup
  • psycho racer
    • Jan 2012
    • 13
    metric car setup
    the rules just came out and they are allowing us to now run racing springs and adjustable cups.what springs should i run and is there anything i can do with my rear trailing arms. should i take off my sway bar or not.car weights 3400lbs got to run street tire i run 245/60 and 255/60 bfgs.any help would be appr.
  • dirt daddy
    • Oct 2011
    • 34
    Rf 900 lf 1000 rr 200 lr 250 take sway bar off redrill ur top arms for pinion angle 6-8 put ur lowers as close up to the rearend housing as u can
    Demon Chassis
    • psycho racer
      • Jan 2012
      • 13
      well i was goin to buy a set of the adjustable trailing arms for the top and how can i move the bottoms up do i need another bracket or can i re drill. thanks for the help
      • dirt daddy
        • Oct 2011
        • 34
        Yes u can jus redill
        Demon Chassis
        • psycho racer
          • Jan 2012
          • 13
          thanks for the help and i mis read the rules its 3200 does that change anything
          • dirt daddy
            • Oct 2011
            • 34
            No u can go softer on both front springs iv went down as low as 750 on the rf at 3400 jus dont let people tell u it wont work it works great
            Demon Chassis
            • psycho racer
              • Jan 2012
              • 13
              do i need to keep the 100 pound split
