I wanted some opinions on a stock intake manifolds, we are running a sbc 350, 450 lift cam 6400 rpm's and 487x heads, 194-150 valves. What is the best stock intake to run on this engine? I have a 4 barrel quadrajet cast iron intake now. What are some other good intakes and casting numbers of them and why are they better? thanks
intake manifold
try the GM performance LT1 / Z28 Cast iron version of the old Aluminum High rise of the late 60's. we gained over 500 rpm on the same motor you described.Originally posted by fast90mini View PostI wanted some opinions on a stock intake manifolds, we are running a sbc 350, 450 lift cam 6400 rpm's and 487x heads, 194-150 valves. What is the best stock intake to run on this engine? I have a 4 barrel quadrajet cast iron intake now. What are some other good intakes and casting numbers of them and why are they better? thanks
What trans are you running ?
I hear these are good. This is not my stuff but I have bought from him before.
