We are finally allowed to run an "IMCA type" upper arm for 2012. Everything else on the front suspension has to be STOCK, 6-7/8 centers, etc, etc, all STOCK. What would a good recommendation be for a metric car running a 3/8 & 1/4 mile Semi banked track.
I would assume a shorter arm on the right and a longer on the left ?
Aluminum vs Steel center arm mount ?
What does the offset arms do ?
I would prefer to not ream out the upper part of the metric spindle if I don't have to.
I see a lot of arms are 6" on center, could you SHADETREE the upper mounting hole or holes and use a 6" arm if it is better ?
If you recommend a part plz include a website, company or part #, if you know it
As stated my car is 100% stock on the front end so plz keep that in mind when recommending.
Thanks for your help.
