I have a set of the tall valve covers with the 2 tubes for the small breathers that go over the tube and stay on with a clamp. It is on the driver side of the engine and after each race there is oil coming out of the back valve cover breather filter. I have placed a sponge inside of the tube and filter hoping it would act like a lawnmower filter and not blow oil out. But even with the tube and breather filled with a sponge oil keeps coming out. I run a 350 with a 7 qt pan with a High Volume Pump. I have thought about the Valve train oil deflector but i dont run poly locks. The oil does not come out of the front filter i dont know why. When i take both filters out for cleaning the front filter DOES NOT let water out if you fill it full, but the rear filter DOES let water out when you fill it full. So do i have a bad filter thats plugged from the factory or a good filter and the oil just gets thru it ???
How do i stop the oil from coming out
