head gaskets
  • fast90mini
    • Sep 2008
    • 50
    head gaskets
    Looking for opinions on head gaskets, I have stock felpro gaskets now on our 350 sbc, a compression test is at 150 lbs, our rules will allow 180 max, I was thinking about using a thinner gasket to raise the compression,is it possible by using thinner gaskets? we have 76 cc heads and block is not decked with 4 eyebrow flat top pistions, what is worth the money and what will it raise my compression to?
  • fast_crew
    • 844
    If surfaces are true and smooth, run the felpro shim gaskets (.019" IIRC), about $15-20 a piece. That would increase compression .4:1. It's worth it.
    Josh K.
    • hogracer3d
      • 511
      Look into the Ferrea's, available from Race Engineering, amongst others......
