front sway bar?
  • Lgss11
    • Jan 2012
    • 22
    front sway bar?
    run a 3/8 mile dirt flat rutted track 3100lb metric frame should we run a front sway bar or just adj with springs and shocks track doesnt glaze over unless sprints are there thanks dave
  • Lgss11
    • Jan 2012
    • 22
    does any one use a front sway bar on a metric
    • dillon_94
      • Dec 2010
      • 72
      depends
      i usually ran one with the left side having about 2 inch longer bolt then the right side. this helped keep both tires on the ground. and if weight were to transfer to the left front say your fish tailing down the straights then it will keep weight on the RF and the theory behind it is it should help have control and not hit the wall.
      just what ive heard from my chassis guy so other people may have other ideas or opinions about them
      dillonsolumracing.weebly.com
      • carowner73
        • Dec 2009
        • 174
        if its rutted up, you dont need a swaybar.
        • Lgss11
          • Jan 2012
          • 22
          What if it turns dry slick ?.hook up and preload bar or leave loose thank you again for your replys Dave
          • dillon_94
            • Dec 2010
            • 72
            ive always set mine up this was so its like you dont have one until your is a oh s**t moment. the track i ran was always dry slick.
