Since i have to go with a shorter spring does anyone know the installed height on a 16" #125 i want to try to keep some spring on the axle when it gets up but i dont think a 13" will do that... Or theres a good chance that it wont... If not i guess ill go with a 13" #200 or #225
left rear spring
Where do you race in vegas I thought the bull ring only ran specials? Im interested in moving there for the warm weather and fun on the lake!
Its warm alright 110* in the summer lol
Its a 1/4 mile hi bank paper clip
Theres also couple in arizona and northern nevada and tons of great tracks in cali
Once in a blue moon they let us run on the 1/2 mile dirt that they run the duel in the desert on...»»*†HÀ†§ HÓ††™««
the way spring rate works is it takes the # rating to compress the spring 1" so..
16" 125: 927# / 125 = 7.416, 16" - 7.416 = installed height 8.584"
another example:
11" 250: 927/250 = 3.708, 11 - 3.08 = installed height 7.92"
The method stated by bush racing will get you pretty close, if you want to be a little more exact measure the compressed height of a spring in the car and multiply the distance compressed by the spring rate to get the weight on the spring. This is the weight that the spring actually "sees" Using wheel weights will put error into your calculation because the spring doesn't support the weight of the wheels, tires, rear end, gears, ect.
