have a metric car hobby stock. we are allowed to run disc in rear. has the stock metric calipers in front, and has the stock camaro style calipers in the rear. i have removed the stock prop. valve and currently have nothing else inline. i have spacers in the rear for the pads. stock metric car master cyl.. front calipers are new, rears & master reman.
ok, i can't get any pedal. have bleed the brakes starting with the farthest one from the master by - vacuum bleeder, pumping 10 times and holding, 1 pump at a time, i even pushed fluid from each caliper back to the master cyl.. can push the pedal and it will lock up the brakes hard enough that they can't be turn by hand but the pedal goes to the floor. so is there i chance that i still have air in the master? it is at a pretty good upward angle and i didn't bench bleed it. seems like it is bypassing because no matter how much i pump the brakes it never gets any pedal but i can feel it kinda wanting too. would like to try a different style master but when the car was built it was built with the stock master mounted to the firewall, so it's pretty tight with the bars. any help would be great. am probally going to try another master. thank 3_7's
