Fixin to build my engine and trans brackets. Right now I have it centered in the chassis. Would be be better there or off to the left?
Engine postition question
I always left mine centered & set back as far as rules allowed, need to make sure there is clearance for headers, fuel pump, steering rod, etc. Never had a problem with just moving it all straight back.Originally posted by chevy370lsx View PostFixin to build my engine and trans brackets. Right now I have it centered in the chassis. Would be be better there or off to the left?
Moving it to the left (which would be the only way to move it for oval) would put a lot of strain on the driveshaft IMO, unless you offset the rearend to the left also. Lots of unneccessary work IMO.Last edited by Dirtman29; 02-26-2012, 07:44 PM.
More important than + or - an inch front to back is..
the height. Get it up as high as you can. It will stick the RF and transfer weight the rear faster.
