clutch burning up????
  • mr williams
    • Apr 2012
    • 3
    I run a small clutch with the 153 tooth fly wheel.It is a ram disk 10 1/2 and a ram pressure plate..I got all of it from speedway motors..I have burnt up two, any suggestions on what is going on.
  • dillon_94
    • Dec 2010
    • 72
    are you loading it on the trailer? that'll cook a clutch fast!
    also check your throw out bearing clearence? i cooked a 5.5 inch disk last year from improper clearence
    dillonsolumracing.weebly.com
    • mr williams
      • Apr 2012
      • 3
      Yea i been loading it by driving it up on the trailer... thanks for the info...
      • C10
        • Nov 2008
        • 359
        Also make sure if you are running a hydraulic release bearing, that the lines to it are not too close to the exhaust. It makes the fluid boil and will slowly release the clutch allowing it to slip
        • rebel1mcelroy
          • Jan 2012
          • 40
          Shouldn't be from loading. Prob got the t.o bearing too tight . Been driving mine on the trailer for years on the same clutch. Unless u don't have 1st gear! Lol
          • dillon_94
            • Dec 2010
            • 72
            depends on loading if you slip it or just drive it onto the trailer.
            more then likely its the throwout bearing that has the wrong clearance
            or the lines getting to hot and heating tho fluid
            • mr williams
              • Apr 2012
              • 3
              thanks for all the info im gonna check the bearing and look at my lines..
