tranny mount steel or rubber with solid engine mounts thanks in advance
power glide help
Mid plate if allowed with rubber mount tho some let it hang otherwise I'd use a polyurethane also be sure dowels are plenty long and I use lock tite Just for ins jmomy daughter my sailor my hero the next greatest generation is our men and women now in harms way Pray for them
Steel mount, reason why is if you run a rubber tranny mount with solid motor mounts, your tranny will have a "spaghetti" like effect, therefore cracking your bellhousing or tail shaft.
I agree to a point I misread the post on the solid mount I've used a poly mount also in this case But solid may be better That's just my way lolLast edited by Chico; 04-25-2012, 02:04 PM.my daughter my sailor my hero the next greatest generation is our men and women now in harms way Pray for them
rubber or poly,..if go solid then there be no way it can flex with chassis an sumptin gotta give! plus rubber an poly will give an separate if you wad it up...white trash motorsports
