bilstein 46mm digressive steel mono tube gas shocks vs.integra stealth 4200 steel bodied shocks $114 vs $75 are the integras as good as the bilsteins as far as fading and life,which work better whats everybodys opinion on a 3100 pound street stock pros and cons on each
bilstein 46mm digressive gas shock vs.integra stealth 4200 steel bodied shock opinion
A bilstien will be better at that level, start talking higher priced integra like IDA which are many times more expensive than the bargin shocks. Bilstiens are rebuildable yourself with cheap parts and can handle what your dishes out.
bilsteins would be more economical then the 4200 series integras. Bilsteins can be fixed if damaged like broken or bent shaft or dented tubes unlike the integras. The 4200 series are a throw away shock hence the cheaper price because the are not rebuildable.
Couldn't agree more. I have tried 4200 series integras, it's great but not as great as Bilsteins since it can be reused when it's a bit damaged.Originally posted by TeamTerminator View Postbilstein shocks would be more economical then the 4200 series integras. Bilsteins can be fixed if damaged like broken or bent shaft or dented tubes unlike the integras. The 4200 series are a throw away shock hence the cheaper price because the are not rebuildable.Last edited by cswitch11; 05-27-2012, 09:44 PM.
