I think i have to much roll. ride heights 71/4lf, 73/4rf,91/4lr,93/4rr. springs 1200lf,1450rf,100lr,200rr.left side 53% rear 50% bite 88lbs. high banktrack 25 to 30%. car bottoms out the right front a arm and the right rear axle tube likes 2 inches of hitting the chassis. car is fast for first part of race than gets loose in the middle of turn. the right rear gains 4psi the left rear 0. rr is 25 degrees hotter.any ideas?
Body roll
Ride heights in rear are to tall. Shouldn't have more than a 1 inch difference between LF and RR. Need to put a 9 inch shock on the rear. Your rear % should be around 53%. Try springs of LF:1000 RF: 1100 LR: 275 and a RR of 225. Have your bite around 160-200. You will see a world of difference!
No time to switch everything. tried 9 inch shock and put 4 rounds in and out on weight jacks. car is the same bad fast for 8 laps than goes loose in middle. an burns the rr off. lr 109degrees rr135, rf 105,lf nothing. car bottoms out the right side. put it on scales 212bite. rf raised 3/8,lf down 1/2,lrdown 3/8,rr up 1/2, 4 rounds out of rr and it raised 1/2 inch is that right, 4rounds in lr it went down. had 13inch 200lb spring in lr but spring could fall out so put 20inch 100lbs in it. car was the same with the 200lb spring. only raced 2 times last year.
There's several things I would change but the one thing that jumps out at me is the left side weight.
If there truly is that much banking, you could go up on your left side weight to something like 55-56% and put your weight low if it isn't already.
What kind of upper a arms and ball joints are you running?
I think you have a typo on the front springs. If not, you have a dead RF/ RR shock or a bad roll center number. What shocks are on it? 1450 lb spring is too heavy.Gator Engineering
I agree, something is definately out of whack here. On a real high banked track you shouldn't experience much roll at all, should be dive mostly.Originally posted by DaveBauerSS6 View PostWhat kind of upper a arms and ball joints are you running?
Do you have all of your weight mounted really high?
You're also too soft at the RR for that type of track in my opinion.
This is exactly right, this is one of the most misunderstood concepts of chassis setup.Originally posted by stock car driverStiffening rf spring just makes it worse, you needed to soften it so it wouldnt bottom out.
Wt transfers to the stiffer spring up front first and more... if your lf was stiffer than your rf it would do something as it is now its doing nothing.
When you soften the RF spring, it forces the LF to support more weight, which results in more grip across the front of the car.
Thanks for the info i am going to put ls weight. checking frontend settings. i think i got the upper on the right its a 91/2 spaced about 1 inch inside the mount. if i put a shorter arm would it move the roll point over an not roll as bad? thanks again.
