If you had the choice would you pick a 78 camaro or 79 cutlass to build a bomber/hobby class car? and why?
78 Camaro or 79 cutlass
here is the rules
FRAME AND SUSPENSION:
A. Minimum wheel base 108â€.
B. ½†wheel studs minimum and 1†lug nuts mandatory.
C. All frames must be completely STOCK from front clip to rear clip. NO altering, shortening, or interchanging of any kind.
D. Upper & lower control arms must be stock factory production control arms, and MUST be mounted in original locations with NO cutting, lengthening, shortening of any kind. NO interchanging. Front & Rear control arms.
E. Uni-body cars may not be connected. Stock shape of uni-body may not be altered in any way.
F. NO reese bars, J-bars, torque links, weights jacks or any other traction-enhancing device allowed. G. Stock type shocks ONLY, MUST be mounted in stock location.
H. Stock type suspension ONLY. Leaf spring cars must have leaf springs ONLY, mounted in original position. Coil spring cars must have springs mounted in stock location, and use stock trailing arms. Urethane bushings permitted.
I second that.Originally posted by balljoint View PostIf you cant do suspension mods to the front or back, camaro.
I you can change the 4 link around and correct the front geometry and beef up tierods etc, metric.
The camaro rear shackle mount area is weak. If you cant support that area and its a bash em up track, you may have to visit the body shop frame machine. Old trick was pull the floor up and lay pipe in the frame channels. A lot of work.Last edited by DaveBauerSS6; 05-06-2012, 11:02 PM.Gator Engineering
how good is the tech at track? by the rules should be a camaro play ground! id still want frame connectors,..its a safety issue!!white trash motorsports
I will call the tech guy and ask. Does anyone have a picture of the frame connector they have? so I can show the tech guy. Thnak you for the information. I have always raced tube chassis cars year ago, so I am learning all I can to build one (non fulltube)
