I have a 3250# metric car with 53* Left
53* cross and 52* rear.
The car has around 200# bite.
Lf has a 1100# spring 4/4 shock
Rf has a 1300# spring 4/4 shock
LR has a 100# 16" tall spring 9/1 shock
RR has a 175# 13" tall spring 3/3 shock.
It has all stock rear suspension with rod eye shock and tubular upper a arms.
The car is good and has been getting better but still needs improvement.
The car is loose off the corner and at time tight in.
The car runs better when the track starts to slick off. The car can get around the bottom but does not have the motor to run down there. The car lays over on the right side and had has good pull when running the bottom but is to loose to run the top.
