Looking for a leaf spring set up?????
  • DaveBauerSS6
    • Jun 2010
    • 566
    #46
    Originally posted by slim10 View Post
    the guys I have helping me are bar racers.They say its not rolling onto the right front going in.Do I want this with leafs?will unbanding the right rear help the left bit more off?rules are just leafs no dampner shock or pullbar.I can use lowering blocks and slider mounts.I read mounting the shocks 3 to 4 inches from the axle will help dampen axle rap right behind left in front.I have a slider on the right and a long shackle on the left.I have a afco 166 rr and a landrum 175 lr I think Im a little light on the left so I thought about adding a half leaf to the front of the left rear any thoughts there.
    First question is how good is it in the entry.
    If the guys are referring to rolling into the RF like a modified; that leaf wont like that. That leaf is not a 4 bar, bird cage. The leaf wont move that much. I want my car to dive into the corner, more level. I mount the shocks at the axle. The leaf is progressive, and slow compared to any other suspension. Let the driver do the dampening.
    The half leaf will help.
    Gator Engineering
    • DaveBauerSS6
      • Jun 2010
      • 566
      #47
      Originally posted by kakahehe0008 View Post
      D?ch thu?t Ph?m L? Gia úp cho b?n, chúc b?n bán d?t hÃ(not a nice word)ng..
      I think I got everything translated right from this dude. He also wasn't sure if you were floating it??
      Gator Engineering
      • skymod43
        • Jul 2014
        • 1
        #48
        I have a 07 robert crump car stacked leafs both side with bird cage on rr and 3" adjustable block on lr and 2" solid block on rr..new leafs and precision performance shocks..I have no side bite what so ever and I cant get on the gas in the middle of the corner out it doesn't matter if its tacky track or slick...can someone please help!
        • grayarea58
          • Jan 2009
          • 14
          #49
          it sounds like springs to stiff or the clamps on leafs are to tight.
          • imracin68j
            • Jun 2008
            • 44
            #50
            Some go fast tips.
            Using this setup - front row outside.
            Suspension Cam
            I run on the west coast in the Super Street division and I can tell you that most of the cars here are very fast. They usually win wherever they go. Here's what I have done. First, you need to be able to take apart the springs and reassemble them yourself. Most spring shops can replace the clamp with a U style which holds the leafs in place but doesn't clamp them. A bolt usually crosses through the top part to keep the springs in.
            Do the fast boy to the left spring. But put some arch into it. From the front of the spring only. The front gives you drive. I put 10 inches of arch. Yes, 10 inches. That means rotate the second spring and slide the 3rd forward and redrill hole. Now when you put the spring in, think of it like a barred up car. Mount the spring in the upper hole you can. like 10-15 degrees. On the back you'll need to lower the spring down with about a 12-15 inch shackle. Make the shackle thick. I use about a 2 inch block on the LR. On the right you can do the same thing to the spring you did to the right. It will create an amazing amount of side bite that you will control with offset in the wheel. If it''s lunging too hard, move the wheel out. Also you'll need a stiffer shock on the RR for this. Like a 5 gas. on the left a 3/5 up 3 hold 5 gas. I use bilstien. Back to the right. You want to mount this in a stock location with the spring going uphill from the rear end about 2 degrees. You need to keep an eye on the uphill degrees when you use this because when the spring flattens out the car looses drive. You will also need a slider on the RR. Mark the slider where the pin is when you start. As you run a few races you'll notice that the pin moves back. When it goes more 1/4- 1/2 inch you need to rearch your spring. Floating the RR sucks in traffic and is slow in the middle. The car has to be driven like a cowboy to race. This setup will be more drivable and produce a lot of drive. To arch your springs get a $100 press. Slide each spring in 2 inches and work it. Don't go nuts. Keep moving it in 2 inch intervals. Only do the front. Take the spring out and lay it on the ground and measure from center. Match the other springs to it when you get 9-10 inches.
            • Krooser
              • Nov 2012
              • 3117
              #51
              Your Super Streets are very much like the WISSOTA Super Stocks here in the upper midwest. Mine is a leaf car… Camaro stub with tube chassis on back. Mopar leaf springs.
              The last leaf car I built I also used Mopar leafs under a Ford frame. I set-up the front eyes lower than the centerline of the axle to try to get as much anti-squat as I could. But this was a long time ago and rear suspension tech has changed so much.
              What's your pinion angle set to? When you say arch the springs to 10" do you lay the spring upside down on a table and measure from the centerbolt to the table? I have plenty of springs on hand…Mopar, Afco and Landrum so I think I'm going to give this deal a try.
              It also looks like you are tossing the car into the corner pretty hard. Are you using a lot of rear brake bias to set it up for the corner? Looks like El Centro is a big 1/4 mile?
              Class of 2019
              • nguyenvinh2
                • Oct 2014
                • 98
                #52
                ban nha quan 2 |nghiệp vụ bảo vệ | cty bảo vệ | chụp hình cưới trọn gói | chup hinh cuoi dep | vay cuoi | sua chua motor dien | sua chua may nen khi
