rubber gasket on 9 in center
  • yenko1
    • Jul 2010
    • 18
    Anyone else have trouble with nuts coming loose using a rubber gasket on the center section?
  • SRXSRULE
    • Jan 2011
    • 217
    Simple solution...Nylon locks nuts. I use them on almost everything on the car. Saves a lot of time and is much safer. Eric
    • TeamTerminator
      • Oct 2009
      • 38
      Ive always used left over rocker arm nuts. Never had one loose since i started racing.
      • C10
        • Nov 2008
        • 359
        I have never used a gasket personally, I just use small string, a little bigger then kite string but not too big, start at one stud wrap it one time, then the next so on and so on. Then use nylon lock nuts, never had a leak or a loose center and its dirt cheap.
        • yenko1
          • Jul 2010
          • 18
          I like the string idea.!
          • 5dirtracing
            • Aug 2009
            • 33
            dont like the rubber gasket had same problem.. I use RTV
