we run a pro stock class with 10 inch tires, car is loose on throttle on the dry track, always a top 5 car, just need to tweek, was wondering which to adjust, im sure its going to be a decrease in stagger, or decrease in rr trail, or maybe an increase in bite. 3000 lbs metric car. car feels like it is hooked up, just wants to turn in a smaller circle than the track is when on the throttle through turn. 7/16 semi banked, fast straightaway, semi tight turns. just wondered if anyone has had that feeling through the turns, and adjusted that out of the chassis without costing entry or exit. thanks
loose in middle help.
