right rear tire gets hot and car is loose in and of corner...175 rr spring 250 lr spring
HOT rr tire
that seems like a pretty big split for spring rates in the rear of car. I would run the split 50lbs or less and sheck bite in car. this should help with both problems. you may also want to check shock travel on left rear and make sure shock isnt picking left rear off ground or pulling up on it in the corner.
We run the 75# split with more rear spring rate and anywhere from 280 to 350 for bite. RR is warm but not hot. Check your right side tire pressure before and right after a race and see what the pressure gains. Ours gains 2# on the right side tires, 1/2# on the lefts.
May sound funny but, make sure left rear is spinning. Depending on what type of rear end under there. You could have broke an axle, stripped axle or drive flange, stripped spool or in my case I didnt have correct spacing between the axles and the left rear axle was sliding out of the drive flange and was getting no spin at all to that tire as soon as right rear unloaded it was like you took the tires off the ground it would break loose and turn up so fast if not for a tacky night probably woulda about wore the tire out lol
First time with a floater
»»*†HÀ†§ HÓ††™««
we run the same springs in a 84 monte, all stock suspension, 13" rear, 11" front 1300 r/f, 1100 l/f no jacks, no nothing all stock per our rules, 3 way pro stock adjustable shocks. for me i was loose from the middle and off corner, for us it was moving the weight from the center and right TO center and left side in trunk, over axle and behind axle, 12 gal fuel cell with about 300lbs lead in rear, 7.5 rearend. After moving the weight to the left and center once the car goes in it sets up perfect and shoots straight out of 4 hard. VS before it would go in ok, push in center and be loose all the way past the flag stand...no traction what so ever....i know people are gonna flip when you see the front spring rates, but everyone who wins down here runs 1000 and up in the fronts.Originally posted by rcstreet1 View Postright rear tire gets hot and car is loose in and of corner...175 rr spring 250 lr springLast edited by 3dinter; 08-16-2012, 11:58 AM.
You need a stiffer RR spring. The tire is hot because its spinning. Your loose going in and thru because the car is not balanced properly. Your exit probably feels loose because your entry and mid turn were never good. Entry is the RR and LF spring. What front springs are you running. Keep in mind when you stiffen the RR spring make sure you get the LR bite back to normal.
Give some more specific details about your car, looks like everyone is guessing long story short you have the wrong setup and without some details your pissing in the wind.Originally posted by rcstreet1 View Postrunning 1000 on front. both sides. when i use to run more bite the car pushed. how big of a split in tire temp should it be...and its not like the car is out of control loose . its just a hand full lol..
shocks, springs and rates, tshocks, how much weight and where its specifically located, type of rearend, tire size, wheel offsets and where, rear drum or disc, using tire spacers, scale % if you got them...etc.etc.etc....
