rear spring question
  • keeter57
    • 125
    We run a 76 monte frame shortened to a 110" wheelbase we run a 1100 rf 1000 lf we have tried multiple combos on rear cant get bite off the corner.Car handles great getting in and thru the center but wont hook up coming off.We have 54% rear 51% left, around 53% cross the car weighs 3400 full of fuel with driver we have tried a lot of different springs on rear with not much change.Any help would be great..
  • ToddSmith16
    • 2854
    How much bite is in the car?
    • keeter57
      • 125
      bout 125 lbs.
      • dirt2
        • 150
        rear springs
        What rear springs do you have now?
        Have you thought about increasing the
        L.S. weight to 54% ?
        • keeter57
          • 125
          yes we are gonna do that this week,225 lr,200 rr.we were running forever with 51% rear and added a 32 gallon cell for more weight but lost our ls weight so we figured we would put it back and see what happens.just didnt know if we needed to up the spring rates since the rear was heavier.
          • ToddSmith16
            • 2854
            get closer to these numbers and you will be surprised....53-54% left side, 54-55% rear and 185-200lbs of bite! With it weighing over 3200lbs I would make LR spring 275lb and RR 225lbs. Good Luck!
            • dirtman45
              • Dec 2010
              • 104
              Like ToddSmith16 says.
              We even run a 300 LR with a 225 RR and 300# for bite. Tight setup but if you learn to drive it hard from mid turn out she really grabs and goes.
              • keeter57
                • 125
                thanks guys we will give it a shot..
                • Ricky76
                  • Jan 2010
                  • 113
                  With that much bite isn't it going to make it very loose getting in ?
                  • dirtman45
                    • Dec 2010
                    • 104
                    With ours it never does seem to get loose on entry. Even with 300 for bite.
                    • ToddSmith16
                      • 2854
                      Well Keeter, How did it go?
                      • 3dracer
                        • 421
                        This thread is amusing.
                        • keeter57
                          • 125
                          havent got to try it yet RAIN at one track and cancelled due to drought on the other ,go figure!!!
